Users should be able to use the "Advanced Find Criteria" Windchill fonctionality from the structure tab of a part looking for a specific criteria (for example on the "number" attribute) on all types of objects (and not only one).
We are forced to choose a "Type" of object from the "Attribute Query Expression" window while we would like to apply the filtering on every objects at the same time in some cases.
Purposal: an "All Types" value should be available to the users.
