When revising a Windchill object, the "Created" on and "Created by" attributes are filled with the name and date of the user who did the revise action.
In order to be able to show the "initial creator" on e.g. a drawing, it would be good tobe able to configure whether the system should keep the initial creator information instead of the revising user information.
