We are using Winchill PDMlink10.0 M020. When we sort a column in aworkspace, it will be good that the "Number" column is sorted alphanumerically. For example, when you sort "general status" column. All the checked out parts are sorted alphanumericaly, all the new parts are sorted alphanumericaly, etc...
It was the case in Windchill PDMlink8.0
