When you remove positions / parts in a WTPart structure a pop-up window "Remove" appears which lists all to be deleted BOM positions. The list shows only the names of the to be deleted positions. It is difficult to check which positions have been selected because the part names can be the same. Therefore, displaying the corresponding part number in this pop-up window would be helpful.
