When using the "Save As" functionality or create a new revision, the secondary contant is copied along to the new copy or revision. This cause problem, since the secondary content are often published to an other system. This could trigger that a secondary content are publish and not related to the CAD document it is attached to.
Adding a configuration settings that could control if the secondary content shall be copied or not would resolve this issue.
