Situation:
- When classification is used - the user should search for existing objects instead of creating new objects
- Example:
- User wants to create a Bolt: Hexagon-Head, diameter x length y
- User should use the new WT11 classification search like:
- Head: Hexagon
- Diameter: 8 mm (Available: 4 - 20mm)
- Length: 25 mm (Available: 10 - 100mm)
- The system should respond the available objects
UP TO HERE => CURRENT FUNCTIONALITY!
- Now there should be a "Create Part" option, which automatically re-uses the inserted values for the classification of the new part
Why is this important?
- In systems with classification users should be trained to search first and create if nothing has bee found
- In this case - the effort for the user should be small to reuse the inserted information - to keep the acceptance of the functionality high
- this is a standard part creation process
