remove attribute value during revise or save as
it is a common requirement that attributes should be cleaned/reset "-" during revise or save as to prevent that incorrect values will be overtaken to the new revision or copy. therefore a configurable listener would be great to prevent customization since this is not simple one taking into account CAD, Workspace, Commonspace, no additional iteration.
6 Comments
BjoernRueegg
This one should be combined with the other Save As idea
during save as it should be possible to change additional attributes
Pekholm
11-Garnet
It should be some way to mark the attribute as version specific. These attributes should not be copied forward upon revise or save as.
STEVEG
I like that idea Per!  It would be so useful!
LawrenceS
18-Opal
Ideally if this were implemented there would be a toggle on the revise or save as screen that a company (and user) config option could be set by default and then the user could override it by clicking the toggle.
I also like the Per's idea of being able to decide which should get wiped and which should not.  Without it, it would be a huge pain to have to always retype all the attributes even though you know that they are going to be the same as previous versions...but there are some that are required to change during revising...
JeffZemsky
PTCModerator
Emeritus
Status changed to: Duplicate
