Currently the use of ressource pools for approver or other roles is supported for promotion requests and setup participant tasks -> based on CS229943 & CS68301 in 10.2 M030
For other routing processes like Workpackages this is not supported and the whole organization can be selected. It is not even limited to a context role or team!
see CS157626
For New Part Request this is also not available and would require a dedicated "Setup Participant" Task.
The behaviour should be harmonized and work in the same way across all kind of routings and workflows.
