start Save As from Replace
We develop machines as a construction kit and add during our production process custom option. Normally the design engineer can use a similar assembly as reference. It would be easier to combine the replace function in the product bill of material. Therefore the save as function shout be included in the drop down menu. Otherwise you need to copy your template separetly or get a copy without BOM.
4 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @AC11  for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration. Here is an example of a recent idea very well documented that drew attention.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
AC11
3-Visitor
    The organization where I work is in the manufacturing industry. I am responsible for product development of ship cranes and coordinate improvements in our internal working process with BOM and special customer reequipments. Therefore, I collect input from around 120 users.
    now Windchill 11.2.1.14
    after 8. July Windchill 12.0.2.5
    during work in BOM new assemblies are necessary and the user has to open these Component to use “save as” and move the new Component afterwards in the BOM.
    skip steps à dialog like you see below
    Less Windows are necessary,
    reduction of working time,
    working direct in the structure where the replacement is needed
olivierlp
Community Manager
Thank you @AC11. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
AD_10399672
3-Visitor
Hello, that would also help us a lot.
Translated by Olivier Le Pord using Google Translate on Dec 15, 2022
Hallo, das würde uns auch sehr helfen.
