As an engineer you want to use the latest possible information , specifically when working in a team.
This includes knowing whether an object in your workspace has been check out by somebody, if you have the lateste or an outdated version of the object, if the object has been renamed, etc.
The General Status in the workspace shows if a document has been checked out by another user.
However, this checked out by ... information is not updated with a workspace reload or refresh, as you expect as en engineer (instead you would need to do some extra click as to Synchroinze the workspace 😞 )
Enabling an update of checked out by information upon reload /refresh of thwe workspace would imporve user efficiency as well reduce frustration of engineers when they find out that the object has been checked out alreday after finishing their modocifcations.
