The tooltip that is displayed in the classification structure, while classifying, is the name of the classification node. This makes no sence. Bettter would be to display the description of the classification node, so the user can retrieve more information about the node he is classifying
in this case, the tooltip should look like "tooltip survey equipment" or any other text entered in description
