use larger icons for supersede
the icon to indicate a part is supsersed is very small. Only 9x9 pixels. superseded information is very important, since this indicates to your user that he should use other parts instead of the one he has found.
create a setting, or enlarge the icon by default, and make it more noticable. Use some Red colors in order to grow the awareness to the enduser something is going on.
If this is not feasable, create a way you can modify the icons in windchill , without actually overwriting the default icons. for example, create a custom location in the windchill directory which is empty by default where you can place your own icons, which are then picked up by wt.
2 Comments
hlinseisen
1-Newbie
In order to change this i would propose that you install Firefox together with the firebug plugin.
con and select "Inspect
Right Click the icon and select "inspect element with firebug" ( without firebug installed you can also use inspect element )
You'll see the path of the icon file
just open the imagefile and resize it - that should do it.
olivierlp
Community Manager
Status changed to: Archived
