wt.occurrence.StandardOccurrenceService.isUniqueOrDeleted()這個API會觸發select count(*)語句是必要的,造成 Database很大的 Loading
3 Comments
BrentLi
18-Opal
[Translated to English]
wt.occurrence.StandardOccurrenceService.isUniqueOrDeleted() triggers the "select count(*) ..." SQL statement. Invoking the API in a loop will trigger a lot of "select count(*) ..." SQL statements in a short period. This results in the high DB CPU usage ratio and has the negative impact for the DB server.
Is it possible to not trigger the "select count(*) ..." SQL statement when invoking wt.occurrence.StandardOccurrenceService.isUniqueOrDeleted()?
毓謝
if the sql script don't use
 SELECT COUNT(*) FROM PartUsesOccurrence A0 WHERE ((A0.usesOccurrenceDataIdentifier = @P0))
Change to
IF EXISTS (SELECT idA2A2 FROM PartUsesOccurrence  WHERE (usesOccurrenceDataIdentifier=@P0))
PRINT 'EXIST'
ELSE
PRINT 'NOT EXIST'
GO
This is a good way to solve this problem, but I don't know how to change this script.
olivierlp
Community Manager
Status changed to: Archived
