We have a requirement to extract the part structure from a PVZ file. While we are currently able to display it using the ThingView widget, the goal is to extract the part structure from the PVZ file and present it in a tree grid.
Additionally, upon selecting a part in the grid, the corresponding part should be highlighted in the 3D view.
I would like to understand:
Thanks in advance!
Thank you Vlad for your response.
I was looking for the pvz extraction inside the Thingworx foundation.
Below post worked for me:
https://community.ptc.com/t5/ThingWorx-Developers/Is-it-possible-to-extract-part-structure-from-a-pvz-file/m-p/996249#M68966
Take a look - "How to extract the components with properties from a pvz file": https://community.ptc.com/t5/Vuforia-Studio/How-to-extract-the-components-with-properties-from-a-pvz-file/td-p/589089
