I searched for navigate 9.1 Install guide via Reference Files Search.
When I opened English link for it, Navigate 9.2 Install guide opened.
9.2 is not released yet and installation is very different that 9.1.
Please correct the link.
The link that you supplied brought me to the Navigate 9.1 Install Guide. To make things easier, I have attached a copy of the Navigate 9.1 Install Guide to this conversation, so you should be able to download it directly from here.
Thanks for reply and proper 9.1 guide.
Unfortunately, for me, I still get 9.2 manual. I think you have some load balancing in place and where I download manual from, there is wrong version of it.
There are both, 9.1 and 9.2 install flow charts below, as you can see, 9.2 also needs ThingWorx Flow.
To retrieve the 9.1 version of the Install Guide, while viewing the PDF, hold down Ctrl+F5. This will force the browser to update the cache with the correct version of the PDF.
Ibrahim
