Hello everyone. I have experience installing and customizing Windchill, but I am new to Navigate and thingworx installation. After refering software matrices, I came to conclusion that Postgre and H2 are the only databases supported for navigate installation. But in my client location they are having below mention servers, so how should I tackle below mentioned problems/ address questions? Any reply regarding the subject would be of great importance.
Question 1: Is it possible to install PTC navigate 1.5 and Thingworx 8.0.1 when there is a windows server 2012 and MSSQL 2016 standard database in production environment? If it is possible how should it be done?
(Requesting for documents and useful links)
Question 2: Is it possible to install PTC navigate 1.5 and Thingworx 8.0.1 when there is a windows server 2008 and Oracle 11g database in test environment? If Yes,
Thank you in advance.
Hello Vinay,
Yes it is possible to install thingworx 8.0.1 and PTC navigate 1.5 with Mysql you can find the documentation at PTC support https://support.ptc.com/appserver/cs/doc/refdoc.jspp=browse_results&Product=ThingWorx&Release=8.0&DocType=2104
Kind Regards ,
Amar Chaube
Hello Vinay,
Kind Regards ,
Amar Chaube
Thank you fro the link Mr. Amar, I successfully installed it long back.
Hi @Vinay_S.
It would be helpful for other members of the community for you to provide the solution. If the previous response was helpful, you can simply select "Accept as Solution" to close out this post.
Regards.
--Sharon
