This is a new installation for test and development, connected to our Windchill dev/test system which is configured SSL/HTTPS with CA signed certificates.
We set up a Thingworx Platform server (MSSQL) SSL with self-signed certs installed Thingworx Flow, and then we installed Thingworx Navigate with fixed authentication and did some setup, generated app keys, did some training and tests etc with the Administrator user.
Then we decided the next step should be to configure the Windchill Authentication but after running the Navigate Configurator and setting up the Windchill Authentication successfully the Thingworx Administrator user is gone? We can login to Thingworx Composer/Flow/Navigate as Windchill users, e.g. wcadmin account.
There are 3 options:
Thanks for your answers but I already started trying another way before I saw them.
4. Delete tomcat\webapps\Thingworx, restart apache, login with Fixed Auth, add the Windchill user to the Administrators group, restore Thingworx folder, restart apache, login with Windchill Auth
true, so basically point 3 if you need to revert back 🙂
