Thingworx Connectiviry with Windchill
pshashipreetham
18-Opal
To do windchill connectivity, do we need to install Thingworx Foundation with an SSL/TLS secure connection?
I am looking to do Thingworx - Windchill Connectivity with Windchill Extension not with the Thingworx Navigate
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
Hi @pshashipreetham ,
If you want to configure Windchill Authentication (SSL client authentication at its core), I believe ThingWorx SSL is not mandatory but recommended. Windchill on the other hand must be configured with SSL.
https://support.ptc.com/help/wnc/r12.1.1.0/en/#page/Windchill_Help_Center/WCAdvDeployGuide/WCAdvDepAuth_ConfigAltAuth_HTTPSClientAuthentication.html#
https://support.ptc.com/help/navigate/r1.9/en/index.html#page/ThingWorx_Navigate/Upgrade_WC_Authentication.html
If it's not too troublesome, configuring SSL for ThingWorx is the safest and recommended.
Even you skipped SSL configuration for ThingWorx installation, you can always come back to configure ThingWorx SSL manually if that becomes necessary for the connectivity you want to achieve.
https://www.ptc.com/en/support/article/CS193947
https://www.ptc.com/en/support/article/CS231610
Tony
Tony
