As per the prerequisites of Thingworx Navigate, Thingworx Flow need to be installed. So, Can Thingworx Flow be installed on a Linux Server? I went through the docs and found no installer for the Linux OS.
Supported Operating System (64-bit only)
Windows Server 2016
Windows Server 2019
ThingWorx Flow 9.0.0 and 9.0.1 is supported on the following versions:
• Red Hat Enterprise Linux (RHEL) 7.5
• Red Hat Enterprise Linux (RHEL) 7.6
• Red Hat Enterprise Linux (RHEL) 8.0
• Red Hat Enterprise Linux (RHEL) 8.1
ThingWorx Flow 9.1 and ThingWorx Flow 9.0.2 and later is supported on the following version:
• Red Hat Enterprise Linux (RHEL) 8.2
ThingWorx Flow 9.3 later is supported on the following version:
• Red Hat Enterprise Linux (RHEL) 8.4
Article - "How to install or upgrade ThingWorx Flow offline(no Internet access environment) in Linux system": https://www.ptc.com/en/support/article/CS322896
Windows Server 2016
Windows Server 2019
