Thingworx Windchill Connector services
egolindano
7-Bedrock
Hi. I've been playing around a little bit with the "Thingworx Windchill Connector" ​ and now I'm confused about a few services, maybe I'm misunderstanding  its use or maybe  there's something wrong with It.
When I try to test each service (create, delete, update) It asks me for some params, a DataShape, Objects, and Modification. So, everytime I add the DataShape and try to add some objects, the service throws me the next dialog.
     Must have a datashape defined to add rows
So. My question is... Can anyone provide me a example of how to correctly use this service? or maybe tell me why am I failing?
Thank You.
Aanjan
(To:egolindano)
Eddison, is there a GET service where you can view the contents? I believe the service you're running right now doesn't know what to fetch. If you're trying to add a row to, say, a configuration table, use the GET service first to fetch the contents and use that to SET. Do take a look at Adam's What is an Infotable blog as well.
