I had a similar problem and I solved it by changing the permission.
Try to change the permission in the thing to everyone.
I am also not an expert, but maybe this helps 🙂
Hi @Nanford.
If you have solved your issue with the help of the previous responses, please mark the appropriate one as the Accepted Solution for the benefit of others with the same problem. If you are still experiencing issues, please provide logging and specifics of the problem so we can assist further.
--Sharon
I still have the issue and I can't share any data, because I am not able to open the Composer.
We are already in contact with PTC and try to solve the issue. I can share the solution, when we are finished.
Hi@ slangley
Thanks for your reply,I still have issue for this problem,my ThingWorx Platform version is 9.1 and the MQTT extensions is MED-61334-CD-091_F000_MQTT-4-0-1-Extensions.zip.
Hi slangley:
I want to use MQTT function to publish my Things properties data when the data changes,but I can‘t find the useful method to work it out.
Best regards.
