Using Dynamic Menu in Master Mashup with Contained Mashups. How to send mashup parameters.
farmerj1
3-Newcomer
I am currently using a Dynamic Menu which will generate items based off the logged in user options. I would like to send parameters to a contained mashup based on which menu item they select. How can we do this.
slangley
(To:farmerj1)
Hi @farmerj1.
Could you provide more information about your use case?  What parameters are you sending to the contained mashup?
Regards.
--Sharon
