need to sso configure thigworx and integrity ?
soumyabiswal
7-Bedrock
I have thingworx 8.5 and integrity 12.2.1,
These two servers are configured with SSL but I want to login thingworx based on integrity user authentication.
is there any way or reference guide to configure SSO with these above two servers???
The only way to get SSO functionality with two separate applications is to use PingFederate. Configuring PingFederate with Integrity is outside of the knowledge of the Navigate team, and you should ask that question on the Integrity board.
The concept is that you perform user authentication with PingFederate, and then authentication to any configured application is handled as SSO by PingFederate. That would get you the functionality you describe, but will be outside of the use case that is the basis for the Navigate instructions. You may need an engagement with PTC Field Services for something that complex.
slangley
(To:soumyabiswal)
Hi @soumyabiswal.
If the response provided by @barko answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
