thingworx mashup
RG_10893406
7-Bedrock
thingworx mashup
We have been following the PTC article CS332905 to create a ThingWorx mashup. However, we have encountered some challenges midway through the process and are unable to proceed further. The details of the challenges we face are given below.Binding the inputs to the output in the mashupWe would greatly appreciate your assistance or if you could direct us to any additional resources that might help us resolve these issues.
6 REPLIES 6
@RG_10893406 ,  I am not an expert at using ThingWorx Navigate, I am experienced in using ThingWorx and the Mashup builder.  If you can provide more information on what issues you are encountering, I will attempt to address your questions.
Pehowe
Thanks for the response.
We have been following the CS332905 article to create a custom mashup. As shown in CS332905 article, we have created the simple custom mashup,
we are trying to configure the bindings for the widgets
Once we click on configure bindings, the below window will open. in the function tab, some output functions should be available.
In our case the output functions are not available. This is the reason we are unable to fetch the data from windchill.
@RG_10893406 , I have reviewed the article/video which you referenced. You may have missed the configuration of the widget.
Did you click on the Gear Icon ?
This should open the "Configure Item Identity". For the widget which you have selected "ptc-nav-item-identity".
This should allow you to select from the drop down list. I would expect 2 entries "Task Identity" and "Part Identity"
Making that selection should display configuration information. You need this to be completed before you go to the next step which you show in your post of the "Configure Binding: ptc-nav-item-identity"
Please review you steps and let me know if anything changed?
Pehowe
yes, i selected the Part Identity in the Gear Icon
Yes we have added that step also, But i missed to mention in the case.
PFA for the document which contains steps which we have followed to create a custom ThingWorx mashup.
Hello @RG_10893406
It appears that  your question received an answer.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
pehowe
