The Clients gadgets provides you a view of the Browsers, Operating Systems and CAD clients being used by your users to access Windchill.
Peer Reports gadgets provide you with a breakdown of the Database and Windchill Server Operating System vendors used by Windchill customers.
Stay tuned for additional enhancements around these gadgets providing drill down views with detail information on usage metrics, historic trend data and device information.
I have just re opened a case with support beacuse, as a not negligible side effect of the new gadgets, it's now impossible to select from the different servers and all data are gone.
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=13182033
See attached image
I just opened a case as well. My Windchill 11.0 systems are still visible but all of the 10.2 systems are completely gone.
Data are back.
So if I'm understanding correctly, there are 2,218 Windchill systems currently sending data to Performance Advisor. Assuming that's correct, how are there more Windchill systems than databases? It seems like there should be a one to one correlation.
It would be cool to have a peer report gadget that showed the Windchill version distribution (and maybe even build) across the data set.
The links to the help documentation are not valid.
Looks like the help links are all working again. Yay!
It looks like an angry Pac Man ghost that is in red - Data Not Available. I glad the data is available again.
