In PTC Windchill Quality Solutions, we are getting TCP error code 10061. pls resolve the issue.
vc-2
1-Newbie
2 REPLIES 2
mfleckenstein
6-Contributor
(To:vc-2)
This issue typically occurs if your database is not connected.
You could check our support portal for the following article.
Article CS192106: "Error "Could not connect to net.tcp://<host-name>:xxxxx/Relex.Security/IAccessManager" upon starting Windchill Quality Solutions Enterprise Edition "
Please follow the link below to access it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS192106&source=emailshare
Best regards
Markus
In PTC WQS11.0, when we try to get report from report wizard, it showing error that "printer not activated, error code -41". Pls help to resolve the issue.
-Viswanatha
