How do I add objects to a workspace without using a config spec filter?
Say I search for objects last modified in a very narrow date range and want to add those exact versions to a workspace. They may be the latest or they may not be. Choosing the "Latest" filter doesn't collect the correct versions and the "As Stored" filter isn't listed as a choice. What is the right way to add the exact versions of the objects returned from a search to a workspace? Thanks.
I think I found the solution.
What do you have this preference set to:
We have it set to "DEFAULT" (the OOTB value.)
I think temporarily changing this preference to "AS_STORED" is the trick. It preserves the "As Stored" config spec during collection, even when it isn't selectable in the filter.
When I did a search just now for files created between 2 dates, I then checked the ones I wanted and highlighted one with the RMB and selected Add to workspace. The files are collected with the Basic tab. Switch to the Advanced tab and it says they are collected with the As Stored spec.
This is in Windchill 11.0 m030.
Don't select just one, select them all.
Selected all, Add to Workspace, switch to Advanced tab. Still shows As Saved.
Yes, mine is set to As Stored.
It does lead to some confusion because of the way Windchill adds to the workspace versus the way Creo loads files and adds them to the workspace on the fly. Windchill we want it to be As Stored. Creo loads them Latest. We have had some issues with getting the wrong files to be exported to manufacturing when the model was saved after the drawing and the drawing was selected for a Windchill Add to Workspace.
We have the same problem with publishing. It's set to publish 'As Stored' and this won't match what Creo shows if the model was saved (and checked in) after the drawing. I have an SQL query I run every now and then for this exact purpose. It locates drawings where the 'As Stored' model does not match the latest version. I then make the designers go back and re-save the drawings against the latest version of the model. (I manually set the drawings back to 'In Work' first so the drawing's revision doesn't have to increment.) I'm trying to beat into everyone's heads that you have to save the drawing last, every time you change the model.
Hi Tom,
I'm very interested in what you've done.
It is possible for you to share your SQL query or at least the guidelines?
Thanks in advance
Here is the SQL query:
-- This query will locate mismatches between drawings models. -- It looks for drawings whose lastest model does not equal the as-stored version. SELECT --DISTINCT TOP(60) ISNULL(lib.namecontainerInfo,'') + ISNULL(prod.namecontainerInfo,'') AS [Context_1], edm.CADName AS [CAD_Name_1], FORMAT(ed.modifyStampA2, 'MM/dd/yyyy') AS [Date_1], ed.statestate AS [State_1], ed.versionIdA2versionInfo AS [Rev_1], ed.iterationIdA2iterationInfo AS [Iter_1], --ed.branchIditerationInfo As [Branch_1], f_edm.CADName AS [CAD_Name_2], --f_edm.idA2A2, FORMAT(f_ed.modifyStampA2, 'MM/dd/yyyy') AS [Date_2], f_ed.statestate AS [State_2], f_ed.versionIdA2versionInfo AS [Rev_2], f_ed.iterationIdA2iterationInfo AS [Iter_2], --f_ed.branchIditerationInfo As [Branch_2], g_edm.CADName AS [CAD_Name_3], FORMAT(g_ed.modifyStampA2, 'MM/dd/yyyy') AS [Date_3], g_ed.statestate AS [State_3], g_ed.versionIdA2versionInfo AS [Rev_3], g_ed.iterationIdA2iterationInfo AS [Iter_3], --g_ed.branchIditerationInfo As [Branch_3], wt.fullName AS [Name_3] FROM EPMDocumentMaster AS [edm] JOIN EPMDocument AS ed ON edm.idA2A2 = ed.idA3masterReference AND ed.branchIditerationInfo = ( SELECT max(branchIditerationInfo) FROM EPMDocument WHERE idA3masterReference = edm.idA2A2 AND edm.idA2A2 = ed.idA3masterReference AND edm.docType = 'CADDRAWING' AND latestiterationInfo = 1 AND statecheckoutInfo = 'c/i' ) JOIN EPMAsStoredMember AS eas ON eas.idA3A5 = ed.idA3C10 JOIN EPMDocument AS f_ed ON f_ed.idA2A2 = eas.idA3B5 JOIN EPMDocumentMaster AS f_edm ON f_edm.idA2A2 = f_ed.idA3masterReference JOIN EPMDocument AS g_ed ON f_edm.idA2A2 = g_ed.idA3masterReference AND g_ed.latestiterationInfo = 1 AND g_ed.branchIditerationInfo = ( SELECT max(branchIditerationInfo) FROM EPMDocument WHERE idA3masterReference = f_edm.idA2A2 AND f_edm.idA2A2 = g_ed.idA3masterReference AND latestiterationInfo = 1 AND statecheckoutInfo = 'c/i' --AND statestate = 'RELEASED' ) JOIN EPMDocumentMaster AS g_edm ON g_edm.idA2A2 = g_ed.idA3masterReference JOIN WTUser AS wt ON wt.idA2A2 = g_ed.idA3B2iterationInfo LEFT JOIN WTLibrary AS [lib] ON ed.idA3containerReference = lib.idA2A2 LEFT JOIN PDMLinkProduct AS [prod] ON ed.idA3containerReference = prod.idA2A2 WHERE edm.docType = 'CADDRAWING' AND ed.latestiterationInfo = 1 AND ed.statestate = 'RELEASED' AND ed.statecheckoutInfo = 'c/i' AND edm.CADName != f_edm.CADName AND f_ed.branchIditerationInfo != g_ed.branchIditerationInfo AND LEFT(edm.CADName, (LEN(edm.CADName) - CHARINDEX('.',REVERSE(edm.CADName),1))) = LEFT(f_edm.CADName, (LEN(f_edm.CADName) - CHARINDEX('.',REVERSE(f_edm.CADName),1))) --AND ed.versionIdA2versionInfo = g_ed.versionIdA2versionInfo ORDER BY edm.CADName, f_edm.CADName
I've also attached the SQL query and a spreadsheet I use to parse the results. Depending on how the filters at the right side of the main page are set, each of the different sections can be generated for each of the users.
To be 100% clear, this is comparing models and drawings with the same file names (minus extension). I am NOT traversing drawing dependencies to find the corresponding model.
Tom,
Does this go across the whole structure of Windchill? I have over 2.5million files in Windchill!
Yes, but performance isn't too bad. I'm no SQL expert but I did try do some tuning. It used to take several hours to run but now it finishes in about 3 minutes on my production system. (55 GB database, 1.1 million CAD Docs, and 10.5 million file vault items) Maybe try running it off hours or on a test system first if concerned.
I am getting command not found on all of the lines from the FROM EPMDocumentMaster AS [edm] to the end.
I am on Oracle 12c with Windchill 11 on Windows Server 2008r2.
It's for SQL server. You will have to adjust it for Oracle.
The 'AS' is an alias.
https://www.w3schools.com/sql/sql_alias.asp
It looks like Oracle doesn't need the 'AS' or the brackets.
https://community.toadworld.com/platforms/oracle/w/wiki/4761.tables-and-column-aliases
