I'm trying to run the following code
public class QueryGroup { public static void main(String args[]) throws WTException { QuerySpec qs = new QuerySpec(WTGroup.class); SearchCondition sc1 = new SearchCondition(WTGroup.class, WTGroup.INTERNAL, SearchCondition.IS_FALSE); qs.appendWhere(sc1); QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs); } }
and getting the following error. Please help.
D:\ptc\Windchill>windchill sh.QueryGroup Exception in thread "main" (wt.fc.fcResource/0) wt.util.WTException: The operation: "find" failed. Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method; nested exception is: wt.method.AuthenticationException at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:810) at wt.services.ServiceFactory$ClientInvocationHandler.invoke(ServiceFactory.java:349) at com.sun.proxy.$Proxy1.find(Unknown Source) at sh.QueryGroup.main(QueryGroup.java:18)
Try running the code directly on a method server. The link bellow has all the details for RMI setup.
