I Configured Windchill for SSO configuration. Using shibboleth as Service Provider and PingFederate as Identity Provider. After SSO configuration DTI is throwing the following error.
Could anyone Please help here.?
ThankYou,
madhu
I have the same problem on my development system. I have not found a solution yet.
Hi..
Please check if Form-Based Authentication enabled for DTI :
Solution Worked in 11.0 M030
- End User DTI worked fine with SSO Enabled
-Consultants - 3rd Party Did not as their Laptops log in as a Different Domain User
- Following the Procedure all the User Login to Open (and then they could select a different user profile (Windchill User) followed by Password/MFA.
Thanks for Solution
