Is there a way to define the default library for a user to check in a CAD document?
jforsyth
We are new to CREO 3. and Windchill 11.0.
We have set up a Library in Windchill where our designers check in new CAD designs (drawings, parts and assemblies).
this Library has a folder named for each designer (I.E. Desinger A, DEsigner B, etc.).
currently the process is for the designer to check in their design and in the check in window they would select their specific folder to check in their CAD docuemnts.
Is there a way so when the Designer checks in their CAD cosuments their specific folder in this Library is automaticlly selected?
thanks for you help.
In your workspace, go to preferences, you can set  a default folder for all your CAD data checked in from that workspace.
Binesh,
Thanks for the quick reply.
I looked but could not find the location where I can define the default folder for the CAD check in.
Is it possible for you to attach a screen shot in the Preferences in Windchill?
thanks again.
Hello John,
Thanks again for your help.
this worked great!
