Navigate ERROR when Navigate call Windchill
Highlighted
Level 10
I configured HTTPS with a self-signed certificate
However, ThingWorx has an SSL error.
Access to Windchill works fine (https: // <hostID> / Windchill)
However, ThingWorx Navigate allows you to log in but an error occurs when importing 3D data.
To find out if this is a problem with self-signed certificates, we are looking for a guide to getting SSL certificates for free.
I received a Let's Encrypt recommendation from a previous question.
But I'm having difficulty with the way I use it on Windows.
I found that I had to leave ports 80 and 443 blank, but this is already in use by Windchill.
Thank you.
Help
