We are happy to announce the new Windchill Customization board! Learn more.
Post WC11 upgrade File Vault issue!
dgraham-5
6-Contributor
After successfully upgrading to WC 11 I'm receiving an error when attempting to access the File Vaults in PDMLink " Failed to load dialog template" . Has anyone ran into an issue like this after upgrading Windchill?
4 REPLIES 4
BenLoosli
23-Emerald II
(To:dgraham-5)
What build of Windchill 11.0 and did you apply any CPS's?
After I did my upgrade to Windchill/PDMlink 11.0 M030, I could not access the Vault Configurator due to a JAVA run version out-of-date error. I applied the CPS06 patch last week and I can now get into the vaults because the code has been changed to HTML code in CPS03. I like the HTML coded interface better.
However, I did run into an issue with Creo View not launching until I disabled the Creo View Check Agent. See https://www.ptc.com/en/support/article?n=CS27008 for details.
dgraham-5
6-Contributor
(To:BenLoosli)
I'm running M030
dgraham-5
6-Contributor
(To:BenLoosli)
Did you have any issues validating your vaults post upgrade?
BenLoosli
23-Emerald II
(To:dgraham-5)
None at all on the vaults that were mounted.
I had some vault folders created but not mounted and the upgrade manager did not upgrade those verify points.
I got a duplicate folder message and the solution was to remove the verification folder from the vault folder and then rebuild it.
https://www.ptc.com/en/support/article?n=CS188159
