Status Code: 500 Error occured
hsano-2
8-Gravel
We using Windchill PDMLink 11.0 M030 CPS6,
and when search from the simple search item in the upper right of Windchill, it get an error like following.
Request URI: /Windchill/wtcore/jsp/com/ptc/windchill/search/Search.jsp
Query String: portlet=component
Status Code: 500
Exception: wt.util.WTRuntimeException: java.lang.ClassNotFoundException: ${domain}.Note; nested exception is: java.lang.ClassNotFoundException: ${domain}.Note
Does anyone know the solution?
This problem solved by PTC technical support.
Follow is same problem and solution.
<https://www.ptc.com/ja/support/article?n=CS101558#_ga=2.19494257.811665916.1518485624-1378123833.1508143170>
