"A referential integrity violation occurred for this operation" i got this error while doing check in process.. and check in failed please any one suggest solution for this
Hello again Sharath
This forum content should be richer.
I think you don't need to find the answer after 1 year.
I experienced same error today.
When the connection corrupts for 1-2 seconds, the integrity violation error occurs.
I would like to find the answer for the error in this forum before I noticed the source of the problem. It take almost 2 hours to solve such an easy situation!
Good day,
Andaç
Hi Andac,
I am trying to checkin an asm file in Windchill from CREO and receiving the same error as you explained above - "A referential integrity violation occurred for this operation"
User is facing this checkin error for last 2 weeks.
Did you mean to say that this error is happening for connection issues? Please suggest.
Thanks in Advance.
This can also happen when you have a quantity mismatch between the assembly file and the WTBOM in the WTpart of the assembly file.
Thanks Ben. I will check that and let you know.
Hi Ben,
I check that and It is fine, there is no quantity mismatch.
Kindly suggest in case I should check/try anything else.
Rajiv
