(1.00* count()) / (sum(query("All Untraced Requirements",Project,count()))/count()) this percentage expression is giving out put null for some cases. Could anyone help me with this issue?
Guest
I have used this percentage expression (1.00* count()) / (sum(query("All Untraced Requirements",Project,count()))/count()) in chart, For some cases the value is null and it is as follows:
Can someone tell what is the reason behind this strange behavior? Thanks in advance.
Re: (1.00* count()) / (sum(query("All Untraced Requirements",Project,count()))/count()) this percentage expression is giving out put null for some cases. Could anyone help me with this issue?
Hello Devaki,
well, without seeing your data it is a bit difficult to help.
A value might be null if
a) you don't have any data
b) this state is not part of the type you are selecting
What always is a good idea is to use IsEmpty() function to avoid such Null values, in your case IsEmpty(...,0).
Hope this helps
Volker
