Background is that when a file is changed, often unnecessary differences are shown due to fixing of typos etc. The common solution is to leave the errors in and not change them, and when we remove the trailing space post-rollout, there will be many differences in the files due to this.
It would be best to fix the bug in the script which writes the revision log comments, so that in the future the code files are less error prone and diffs are easier.
