This question is Not Answered.(Mark as assumed answered)
Joe Summers Jun 14, 2016 10:22 AM
Would like to know if there is a trick or function that you can use to show your query selection criteria on the report heading, like when you run a report as of a date it would be beneficial to see what information the report was run for. Instead of having to hand type the information in to the report each time you change the query selection criteria.
And the same ability to show this on your charts on Dash boards.
I need to show some selection but not all.
