Ability to propagate intra-document relationships using the propagate trace wizard in Integrity Lifecycle Manager
When trying to propagate traces linking items inside the same document in Integrity Lifecycle Manager an error occurs:
     MKS131481: Invalid trace propagation requested. One of the start segments is the same as one of the end segments.
​The Propagate Traces operation does not complete.
The Wizzard should be able to handle such situations.
3 Comments
KartikOak
Hello Mathias,
                        Can you provide a use case scenario that clearly describes when you run into this problem? I think I know the scenario but want to be sure and I'm also interested to know what is the current workaround you are using?
Kartik Oak
ckirsch-2
Today I ran into the same problem. I have a document where system and software requirements reside inside the same document with traces between them. After creating a branch of that document the traces are lost and it's not possible to propagate them.
Is there a workaround available?
kloetman
3-Visitor
I have the same issue. The requirements experts use the "Is Related To / From" trace to track interdependencies of requirements on system and software level. These relationships can´t be propagated right now.
Currently I´m working on a scripted workaround but it would be better if this feature would be added to the propagate trace wizzard.
