Security Alert Log4j Security Vulnerability. Click here to know more.
Ability to see Parameterized OSLC ILM requirements in Modeler
Parameterised requirements are very powerful way to reuse requirements between variants. Correct OSLC integration is not showing parameter substitution when using requirement through OSLC browser in Integrity Modeler. This function is very important in order to have a consistent connection between Integrity Modeler and Integrity Lifecycle Manager.
4 Comments
PatrickOllerton
Could you provide more details on your use case?
thanks,
Patrick
segotlingm
3-Visitor
Hi @PatrickOllerton
I've attached three images showing the use case. When you enter requirements in ilm, you have the ability to parametrize them (Image 1 and 2). When these requirements are shown in Integrity Modeler through OSLC Integration, the parameter substitution is not working. Instead, the interface is showing the parameter name in double curly braces {{parameter}}, as shown in Image 3. This impacts the readability and presentation qualities of the text in the description box.
Image 1Image 1
Image 2Image 2
Image 3Image 3
Sincerely
Mattias
PDM Developer, Tetra Pak
PatrickOllerton
Thanks, I will discuss with our development team and get back to you.
Patrick
PatrickOllerton
This is something that needs to be resolved in Windchill RV&S OSLC server output and they are considering for a future release. We'll post any updates here, or you could try raising a Support case as it might be classed as a defect.
regards,
Patrick
