This idea comes from the Case C14144085 - Issue to extend development paths on some subprojects.
Please add the ability to see what the configuration of a extendable DevPath was at time of checkpoint.
The only way we know to get this for sure is from the database. You can make an educated guess by viewing normal and variants, and by the build numbers in the build project.
