Currently it's not possible to re-use a Test Step inside a Test Case.
So if you have very fine granular Test Steps, e.g. "Go To Homepage" and want to use that multiple times in your description of Test Steps inside one Test Case, then you need to create multiple Test Steps called "Go To Homepage 1", "Go To Homepage 2", "Go To Homepage 3",...
It would be much better, if the same Test Step could be re-used multiple times.
