Ability to view requirements doc structure in Modeler OSLC browser
The requirement document in ILM has requirement nodes organised in a particular order under different heading but when browsing this document in Integrity Modeler's OSLC browser, all requirements are shown in alphabetical order (a flat list). There is a strong need for a configuration so that requirements are shown as it should be based on the document structure in ILM.
Typically in a requirement and test document there are 100s of requirements and it's not practical to use them through OSLC browser without a node structure for a production environment.
2 Comments
PatrickOllerton
Alexandrite
Status changed to: Under Consideration
Thanks for the product idea. We agree this would be a good way for users to interact with Integrity Lifecycle Manager data and are planning for a future release. This enhancement is ID ART19-2737090, which you can use for tracking.
For now, depending on the OSLC property mapping in ILM you may be able to see the type of the item so Sections are denoted.
You may also be able to see the hierarchy (in the shortTitle in the mapping below) - the image below shows the 3rd requirement in section 1.
regards,
Patrick
segotlingm
Visitor
Hi @PatrickOllerton
Thanks for considering this idea for improving the software. Meanwhile, is it possible to map two fields in Integrity Lifecycle Manager OSLC mapping file so that we can see "Short title" and the "Text title" in the Integrity Modeler OSLC browser view?
Sincerely
Mattias
