The requirement document in ILM has requirement nodes organised in a particular order under different heading but when browsing this document in Integrity Modeler's OSLC browser, all requirements are shown in alphabetical order (a flat list). There is a strong need for a configuration so that requirements are shown as it should be based on the document structure in ILM.
Typically in a requirement and test document there are 100s of requirements and it's not practical to use them through OSLC browser without a node structure for a production environment.
