When there are version 0.1 and version 0.2, I want to let you maintain the trace on the version 0.1 side.
and
When some kind of circumstances occur, I want to change the trace on the version 0.1 side.
But in management clients,
With type - document model - important edit field
and Type - document model - version edit field
can register one either field.
Can both properties not set the same field?
