Add Integrity Support for SiteMinder with SAML and Server Clustering
Integrity has a vendor-supported integration with CA SiteMinder for authentication.  However, the Integrity to SiteMinder integration does NOT currently support:
  • Clustered SiteMinder servers (for redundancy/load balancing)
  • Use of the Security Assertion Markup Language (SAML) standard (for Single-Sign On support)
Both of these current integration constraints (clustering and SAML) are typically recommended technologies for enterprises, making the existing "SiteMinder Integration" far less useful.
By expanding the current SiteMinder integration to support these security enhancements, PTC would make their support of an enterprise-leading security tool much more relevant and useful...since no integration is currently possible with Integrity Lifecycle Manager if the enterprise uses a clustered SiteMinder implementation (for redundancy) or the SAML standard for implementation of Single-Sign On convenience.
1 Comment
KartikOak
Status changed to: Delivered
Windchill RV&S, since 12.2 does not have support for SiteMinder.
At the same time, it has support for SAML with the Web interface. The Swing Client will work with Basic Authentication in the same ecosystem where the Web is being used with SAML - SSO or other client interactions with OAuth
Kartik
