Many of our projects used Document Revisions (command Document > Increment Revision).
This command provides three options, which are very helpful in different Use Cases:
With Integrity 10.5 Document Revisions were replaced with Document Versions.
When a Document Version is created there is no option to decide which elements are versioned.
The caused many problems in our projects, therefor we decided to disable Document Versioning.
Fields in versioned documents, including traceability, cannot be trusted describes another idea for this problem.
My idea is quite simple:
Just reimplement/ enable again the above mentioned options, which were already available for Document Revisions.
