in relation to Integrity 10.9:
Since the 'improvement' for the view on the Subprojects in 'Add Subproject', you are no longer able to browse for subproject in the archive.
To readd dropped subprojects you have to know the exact path to this subproject and type it into the text field, because there is no browsing possible.
If you do not remember the name of the subproject (because it was renamed 2 years ago) there is no way or a complicate way of identify the possible subproject with 'view as'.
You have to make a 'view as date' on every possible project parent to find you missing subproject.
In our opinion it is a usability deterioration instead of an improvement.
