Are you using Document Versioning? In the 11.0 release, you will be able to add comment/description on a specific version during a document check in process.
thank you very much for your feedback. Yes, we are using Document Versioning for different scenarios. It sounds good, that this function will be available with 11. Thank you very much again for your feedback and your review of the ideas.
