Currently, the Integrity Client has a feature where users are able to search Configuration Management files by name. However, this feature does not exist on the Web version of Integrity. In many respects the Config Management Web UI is much better, but without the ability to search, our users cannot use it properly.
See case 15822055 for additional information.
