Add functions to modify the font size of integrity overall display
The default font size for Integrity client is too small.The user feedback that when viewing documents they feel discomfort due to the size of font are too small. It's a urgent need to support Integrity client to support customize the global font size of integrity client.
8 Comments
vichavan
8-Gravel
With the new UI work being planned this concern will be addressed, we are committed to deliver a solution with great usability and user experience.
acoosemans
Good to hear!
Any idea when a new UI would be released?
There are quite many UI related requests on the forum, maybe someone can comment on those whether they will be included or not.
I have trained hundreds of people and see the same mistakes coming back all the time because of some counter intuitive designs in the current UI. I'd be happy to have a call with anyone of your team.
vichavan
8-Gravel
This is going to be a multi-release effort. We are in the planning stage now. Great to hear you are willing to help/contribute, we will get in touch soon.
And yes, we are going through the conversations on this forum!
VolkerEckardt
The font of the text field (richtext) you can change by updating the file:
\data\im\richcontent\styles\screen\default.css
body, table { color: #000071;
font-family: arial, sans-serif;
font-size: 10pt; }
This includes also the font size for the headings. This is one of the first things I am changing for all my clients:
h1 {font-size: 18pt;}
h2 {font-size: 16pt;}
h3 {font-size: 14pt;}
h4 {font-size: 13pt;}
h5 {font-size: 12pt;}
mmorris-2
3-Visitor
Has there been any progress made on allowing Integrity users to increase the font size of the user interface?
leandrohbatista
6-Contributor
We just upgraded from 11.2 to 12.3.1 and the font size got too small. Users that are located at laboratories and need to use the tool are complaining about it. We also have seen that users can make mistake due to this issue. An example is when they are selecting an item from a pick list or even just reading some text.
Is there any workaround for this issue? Is it acknowledged and also planned to be integrated in the coming releases?
Leandro
cummins2019
Please follow the below steps for the font size issue.
  1. i)  Go to <client_install_dir>/bin at C:\Program Files (x86)\Integrity\ILMClient12\bin
  2. ii) Select IntegrityClient.exe right click and go to Properties dialog.
iii) Go to Compatibility tab and Check the ‘Override high DPI Scaling behaviour’.
  1. iv) Select the ‘Scaling performed by’ value to "System". Click OK. (See attached - IntegrityClientEXEProperties.png)
  2. v)  Restart Integrity client or you may need to restart the machine is restarting client does not solve the issue.
This is workaround for this issue.
-Kaustubh
KartikOak
Status changed to: Alternate Solution
The issue is with core Java and an alternate solution has been suggested on this thread. There isn't a plan to enhance this further unless there are fixes from Java.
Kartik
